Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
dz68bc bluetooth adaptor not working after win 8.1 upgrade
jfasc
Hi All !
I've upgrade my computer to win 8.1 now my Motorola Bluetooth adaptor is not working. When I click the icon the documents folder opens up. I've tried several different drivers all with the same result.
anyone know how to fix this?
Thanks John
Jose_H_Intel1
Hi John, it seems the support for Windows* 8 is as-is. The DZ68BC is listed under discontinued boards.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported Operating Systems
I would try getting the device Hardware ID and searching for Windows* 8.1 drivers over the internet.
The Hardware ID can be obtained from Device Manager, double click the Motorola* wireless adapter, go to the Details tab, Select Hardware ID from the Property drop down menu.
jfasc
I found a work around online, it basically creates a batch file that starts the Bluetooth program, and then I created an icon and pointed it to the batch file
works well enough for what I need it for.
thanks for responding
john
