Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
dz68bc not detecting RAM
EL_pe
Hi, i have a dz68bc with 4 8GB ram modules installed totaling 32GB but bios is only detecting 2 of them, 16GB
the slots detecting the ram are slots DIMM1 and DIMM2
this motherboard is suposed to work with up to 32GB of ram of up to 1600 MHz
i have tested all modules and all work
the part number of the ram is:
KHX1600C10D3B1/8G
processor is i7 3770K 3.5GHz 8MB
are this ram supported with this motherboard?
EL_pe
I dont know what happened, i just installed the latest windows updates, restarted the computer and now it detects the 32GB
EL_pe
The problem continues, the computer froze i had to shut down manually, then before the computer started again, BIOS showed a warning saying there was a memory decrease, press enter to continue, now im back to 16GB again.
i dont know what to do, im thinking the motherboard doesnt support 32GB ram and i have to get a better one...
EL_pe
Today i started my computer and now it detects the 32GB again!!
ill wait a couple days to see if it stays that way!
Silvia_L_Intel1
LoFish,
You motherboard supports the total of 32GB of memory.
Since the Memory controller Hub is now on the processor, the RAM needs to be compatible with the chip.
I checked the memory you are using and it is totally compatible with your Intel (R) I7-3770k processor, however please let me know which is BIOS version do you have installed on the board?
EL_pe
Thanks Sylvia, my BIOS version right now is 0039
