I got an issue with my board. IT will not boot. I have move the memory stick around but still get the blue screen during system boot and can not repair itself. Just above the powers supply there is a flashing blue light and another setady read. This read reads VR Hot.
ABove the processor are the voltageregulator lights . They are blinking green .
The documentation say that this is an over voltage. I remove all teh ground and devices including drivers, memory sticks and the CMOS battery. BUt the red light remain on steady.
IS this a problemwith th eboard or processor.?
Also, the system will not boot and does not repair.
Intel doesn't make the boards anymore. Is there anyone in the community that can answer this question?
Elyse B.
Intel
Please make video showing the lighting sequence from the point of power-on.
Also, are there POST codes being displayed on the monitor? If so, please make video showing the POST codes that are being displayed.
The HD Activity LED being on solid is an issue indicator as well. What happens when you power on after disconnecting all of your SATA drives?
Have you tried using a different power supply?
