Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
dz77re-75k - graphics performance settings in bios
Community Manager
Greetings,
I am running crossfire on 2 asus HD7850-DC2-2GD5
Currently in the bios Overclocking Assistant, is appears that the default settings are:
The "Set This PC's Performance: slider is at 1.150 Gz
The "Graphics Max Multiplier" is set to 23
The Graphics Voltage Offset (mV) is at zero
The Turbo Ratios is at 33
My question is that can I move the slider up at all for these graphics cards?
The graphics card specs are -
Graphics Engine AMD Radeon HD 7850
Bus Standard PCI Express 3.0
Video Memory GDDR5
Engine Clock 870 MHz
Memory Clock 4840 MHz ( 1210 MHz GDDR5 )
RAMDAC 400 MHz
Memory Interface 256-bit
Resolution D-Sub Max Resolution : 2048x1536
DVI Max Resolution : 2560x1600
Interface D-Sub Output : Yes x 1 (via DVI to D-Sub adaptor x 1)
DVI Output :
HDMI Output : Yes x 1
Display Port : Yes x 2 (Mini DP)
HDCP Support : Yes
Power Consumption up to 150W1 additional 6 pin PCIe power required
