Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
dz87klt-75k doesn't recognize AMD XFX HD 6990
LTTAL
I hope someone can help me on this issue. Here is my current system info:
MB: dz87klt-75k
CPU: i7-4770K
GPU: AMD XFX 6990
MEM: 32gb Kingston's KHX24C11T3K2/16X
PS: 1000w Antec High Current Pro
OS: Windows 7 Pro x64
Issue is that the motherboard does not recognize my AMD XFX 6990 in the bios screen. I can not use it as a primary video display. When I force it to be the primary PEG, I get 3 beeps cause of no active video card. On board video works i would like to utilize my graphics card. I think this is a common problem with the 8 series chipsets. I had tried this card in an ASUS Maxiums VI Formula with the same result. This card works great in my old setup below:
MB: DX58SO
CPU: i7-920
GPU: AMD XFX 6990
MEM: 16gb Kingston's KHX24C11T3K2/16X
Any help would be greatly appriciated.
- LILTTALK
  • 4 Views
  • Tags: none (/message/213097 add)
  • Categories: Compatibility , Install & Configuration , Performance & Optimization
Silvia_L_Intel1
Hello LILTTALK, for this kind of behavior what we can recommend you to do is check with the video card manufacture for a firmware update.
Also, make sure you have the latest BIOS version available for this motherboard.
You can also try to change UEFI boot to LEGACY boot in BIOS before installing a graphic card. We saw some good results when doing this.
Additional to that, you could remove the CMOS battery and leave the system without it for about 10 hours. Then, put it back in and restart
If you are using a video card, I would recommend you to please remove it and also disconnect the power supply from the board.
