Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
enter password to unlock system dh77kc
JCesp
Muy buenas tengo una placa intel dh77ck, al encender
ya intente con todo los rested de bio sacar pila etc.
hay alguna manera de saber cual el es password (nadie coloco password al bios)
otra manera de de entrar
gracias
AlHill
To enter the bios to reset the password(s), please review https://downloadmirror.intel.com/20952/eng/DH77KC_TechProdSpec04.pdf https://downloadmirror.intel.com/20952/eng/DH77KC_TechProdSpec04.pdf , section 2.3 on page 58 and table 35 on page 59. You may also want to read section 3.10 on page 74.
Doc
JCesp
check all documentation and bios reset jumpers
still with the same
there is a universal password intel? or software for usb, cd recovery bios thx
AlHill
With power off, when you set the jumper to "configuration", and then turned power on to your PC, did it enter the BIOS?
Doc
JCesp
with Configuration Jumper Settings 2-3
It is seen on the screen enter password to unlock sytem!!!
To be more specific
bios has detected unnsuccesfull...........
pres yes
warring chassis intrusion
AlHill
Unplug the chassis intrusion switch from the motherboard, or defeat the switch.
Unplug the AC from your power supply.
Remove the coin battery.
Wait 30 minutes.
Replace the battery.
Put the bios jumper on 2-3
Plug In the AC to your power supply.
With the chassis intrusion switch removed or defeated, turn on power.
You should be in the bios.
Doc
JCesp
thx but same mistake
enter pass................................
try all bios settings reviewing internet(video), jumper 2-3, replace batery, power supply new, none works and documets dh77kc.........
AlHill
Sorry, I am at a loss on this one.
Perhaps one of the Intel support staff can help.
Doc
n_scott_pearson
Super User Retired Employee
Have you tried just pressing when it asks for the password?
Did you just replace or add a hard disk drive? If you did, it may be that this hard disk drive has an encryption password set on it and it is asking for this password...
If neither if these suggestions helps, I am at a loss as well. Doc's suggestions are exactly what I would have answered if he hadn't beaten me here...
...Scott
