Community
cancel
Showing results for
Search instead for
Did you mean:
sredk
fan speed is constantly changing
Jump to solution
Fan speed is constantly changing from 811 to 843 revolutions per minute several times a minute.
What is the reason - the motherboard or fan?
And it is not immediately apparent, but after two months of use.
RMoor7
Nothing to worry about.
The fan speeds are an actively trying to cool the MoBo devices.
That is, as the selected primary and secondary control components (CPU, PCH, Mem, VR, etc.) change temperture from their designated setpoints due to there processes and utilization the fan will change speed to support cooling the device.
Also, the variation you are discussing is only 4% fluctuation.
RMoor7
sredk
Thanks for the answer. I was worried about the noise from the fan and I thought that this is due to changes in speed. But now put another fan and everything is OK. And the speed of change in the same way.
