Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
front panel header
dson2
HELLO FRIENDS,
CAN ANYONE SPECIFY HOW THE PIN NO 9 ie 5V DC PIN USED IN COMBINATION WITH THE OTHER PINS..OR IF I CONNECT A LED + TO THE PIN NO 9 THEN WHERE DO I CONNECT THE - NEGATIVE...
Silvia_L_Intel1
Hello Deep84,
Let me inform you that Pin 9 is not needed for the available LED options used. To use pin 9 for other purposes, it would be needed a proper grounding.
Regards.
Silvia_L_Intel1
Hello Deep84,
Regards.
