Intel® Desktop Boards
Peer-to-peer support only
gpu at 0%
johnnysink40
i have an hp 15 notebook with the intel (R) graphics...all updates are done but gpu is still showing 0%....is there anything else i can do or should i take it to get serviced?
AlHill
Is everything else running OK?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
johnnysink40
ah the cpu and ram are running fine just no gpu....I will do that thank you
AlHill
Are you getting any display, or no graphics at all?
From where are you getting this "0%" data?
johnnysink40
i have a display but vidoes are extremely laggy and when my son plays his games they barely work...i have a window that shows the cpu, gpu and ram usage as a moving graph. cpu will normally be around 60 to 80%, the ram around 70% and the gpu at 0%
johnnysink40
AlHill
What utility is this?  What are you seeing with task manager on the performance tab?
johnnysink40
its part of the gaming app xbox game bar
AlHill
What aree you seeing with task manager?  It sounds like this gaming app has a problem, not your graphics.
johnnysink40
i dont even see a gpu graph in the task manager but the computer says it has one.....i dont know lol i have no clue.....i should just buy a new one
johnnysink40
file attached
