Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
how to make BIOS change to DZ68DB graphic at power up
We are using the Intel DZ68DB motherboard with i7-2600K CPU.
This mb has integrated graphic and the power up graphic output is the build-in HDMI port.
We have a Radeon 6670 PCIe graphic card installed. We want this card HDMI output enabled at power up as primary default display.
How do I make change to BIOS to boot with this display? Thank you.
Highlighted
Community Manager
1 View
Re: how to make BIOS change to DZ68DB graphic at power up
Plug your monitor into the 6670.
Then in bios, set display to auto and it shoudl fire right up.
I have the same setup but with a GTX card.
