Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
i7 3770 not stable at 3.9 ghz..
AMani4
hye
just ordered a asus h77 v model for i7 3rd gen 3770 but now having difficult time as Intel suggest that 3770 uses 1 and 2 core at 3.9 GHz and 4 core at 3700 MHz at full load .. but when checking with prime95 with only 2 threads it mostly stables at 3.7ghz but for a sec or two reaches 3.8 and some times reaches 3.9ghz ... only for a sec . my question is why this is not stable at GHz Intel suggest .... the temps iam getting seems fine 60-c at full load its always stable at 3.7 when i test with 8 threads...or 2.thread.......... iam not getting why its never stop at 3.9ghz for even 5 SECONDS... IT DISAPPEARS WITH A BLINK OF AN EYE ... IS THIS NORMAL..why THIS ISSUE.IS CAUSING. ANY HELP....
Jose_H_Intel1
Hello mani008, please note that the standard clock speed of the processor is 3.4 GHz as per link below. Turbo-boost works automatically and goes from 3.4 up to 3.9 GHz depending on several factors such as temperature, voltage, power and load.
http://ark.intel.com/products/65719/Intel-Core-i7-3770-Processor-8M-Cache-up-to-3_90-GHz?q=Core%20i7... http://ark.intel.com/products/65719/Intel-Core-i7-3770-Processor-8M-Cache-up-to-3_90-GHz?q=Core%20i7...
The behavior of your processor appears to be normal; however, just to make sure I would recommend running the Intel® Processor Diagnostic tool.
http://www.intel.com/support/processors/sb/CS-031726.htm Processors; What is the Intel� Processor Diagnostic Tool?
