ik heb een Intel DG965SS mainboard , in Bios staat inplaats van model en firmware nummer alleen maar YYYYYYYYYYYYYYYYYYYYYYYYYYYY bios update werkt niet geeft die fout aan en ook via recovory mode , werk niet en nu doet ook me geleid het niet meer........ wie weet hoe je dit kan oplosen????
It looks like the Flash IC that is used to store the BIOS - and its identification and configuration information - has been corrupted and may likely be failing. Unfortunately, there may be no recovery from this...
Sorry I don't have better news...
...Scott
In this case, you could try a BIOS recovery to a later version; I'm not sure if you already have the latest version but if you do then most likely it is as N.Scott.Pearson says Flash IC that is used to store the BIOS has been corrupted.
In case you want to do the BIOS recovery, you can follow the instructions here:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
Also you can download the BIOS version at the following link:
https://downloadcenter.intel.com/product/22638/Intel-Desktop-Board-DG965SS Downloads for Intel® Desktop Board DG965SS
Regards!
