Hangs motherboard code EB, network card is inserted through an adapter PCI-E 8x to PCI-e 1x, Cards - intel CT desktop it works. How to solve the problem? intel i350t2 rev. PCI-E 2.1 and intel 2800mt (NM10) 1.0a. May be the problem?
The same card works on another board in the PCI express x1
I think that the problem is in the BIOS
So what could be the problem?
Hello Sandr, it seems like the problem that you are getting is related to compatibility. I recommend you to test with a different card on the motherboard, if it works you can confirm that it is related to compatibility between the parts.
Regards.
Yes. On board Intel CT desktop works. I understand that you use the server network card, but it is certainly not to understand why it is not working. EB fault bios says accessing storonnney ROM memory, I think that the error in the BIOS.
