Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
intel D945GNT compatibility
jpiou
my mother board is intel D945GNT is it compatible with windows 7?
AlHill
It will probably work. However, it is not officially supported. Look under "discontinued boards" in this link:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html Supported Operating Systems for Intel® Desktop Boards
Now, all that said, this is more than 12 years old. Component failure is likely a reality.
http://downloadmirror.intel.com/15174/eng/D945GNT_TechProdSpec.pdf http://downloadmirror.intel.com/15174/eng/D945GNT_TechProdSpec.pdf
I personally would not try to make it work, unless you are doing this just for the experience.
Doc
n_scott_pearson
Super User Retired Employee
Since Windows 7 was never supported (by Intel) on this board, no driver packages are available. As Al said, it is possible that this board is old enough that drivers for it are included in the Windows 7 installation packages. You will just have to try if you want to see if this is the case.
jpiou
jpiou
Community Manager
Thank you Al Hill and N. Scott Pearson for sharing this information with us.
Ivan.
