Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
intel desktop board dg33bu help
computernerd101
hello! i need help with my intel desktop board. windows is missing the pci simple communications controller driver. i tried updating it in device manager, didnt work. i tried scanning for hardware changes, didnt work. i tried the intel management engine component installer, still didnt work. i tried updating the bios. it updated successfully but still didnt fix my issue. i tried the wierd online solutions and they didnt work. can you guys please fix it?
system specs are: core 2 duo 6320 1.86 ghz. 2.5gb of ram. 2 tb storage. latest bios installed.
i hope this will help.
AlHill
Do not worry.   You do not need this driver.
computernerd101
well if i dont need it then why dont any graphics cards show up in device manager.
AlHill
That device is the MEI.  You do not need it.
What OS are you using?
computernerd101
i am using windows 7. and i definitly wnat my card to work in this so i can play games
AlHill
Did the graphics card ever work?  What model card?
computernerd101
yes it works, but all i know is that its a nvidea gygabite card with 2gb ram
AlHill
You are going to have to do better than that.  Did it EVER work?  Did it ever work on this motherboard?  What model is the card?  Take it out and examine it for a model number.
For help, you need to provide as much information as you can.  And, you may have to accept the reality that this 2007 board has failed.
computernerd101
ill look on the card, but you should know i got this computer at savers a couple of days ago
computernerd101
So the card is a gigabyte gv-n630-2gi rev:3.0
AlHill
I do not know who or what savers is, but I would take it back to them.
Let me ask the questions again:
Did the card ever work on this board?
Did you see it work?  Did you see it work with Windows 7?
Did you install the card yourself?
Answer these questions.
AlHill
From what I can see about the card, it should work with your board.
https://www.gigabyte.com/Graphics-Card/GV-N630-2GI-rev-10-11#ov
This is assuming that the card is good, and that the board is good.
computernerd101
I put in my own card. And savers is a thrift store here in Phoenix. And I know the card works with windows 7 because I have used it in another windows 7 machine before this one.
AlHill
Then, the board is bad.  Return it.
computernerd101
there has to be another solution. im not giving up
computernerd101
i have put too much time into this. and they dont do returns.
AlHill
Check the bios for a video setting (onboard, external, auto) or something like that.
As I said previously, the board is 13 years old.   Component failure, if not already, is going to happen.  Also, the video slot could be bad.
Why would you purchase a 13 year old board?
computernerd101
i have it set on auto. the reason i bought it was because it was cheap and already had a case.
AlHill
Sorry, it looks like you have a boat anchor.
computernerd101
i set it to peg and still nothing happened. anything else to try?
AlHill
Do you know what your bios version is?
