Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
intel dh77eb bios update
SAhme15
hi i am in need of urgent help because today i went to a computer shop and bought a new psu and gpu that is an asus amd r9 270 and corsair vs550
and asked them to install the psu and gpu on my existing build which is i5 3570k mobo intel dh77eb corsair 4gb memory this system i am using for the past 2 years and never updated bios.
when the shop technicians installed the gpu and psu they found out that the psu is working and the mobo is not able to handle the gpu because of older bios and we need to upgrade it i said ok when they upgraded they were still not able run the gpu more over my mobo is not even able to work without the gpu with the integrated graphics and they are now sayinng that mobo had some fault and that its pci 3.0 slot is not working so you have to change your mobo i asked them to install the previous bios version and show me that it was not any of your fault which caused my mobo any problem so they said come tomorrow amd it will be ready
now after this long story i want to ask that is the update necessary and if it was then why mobo is not able to handle the gpu after update of bios
i also want to ask that if my pci 3.0 slot was not working then why iwas not getting any trouble in the pas was it
and asked them to install the psu and gpu on my existing buil which is i5 3570k mobo intel dh77eb corsair 4gb memory this system i am using for the past 2 years and never updated bios.
when the shop technnicians installed the gpu and psu they found out that the psu is working and the mobo is not able to handle the gpu because of older bios and we need to upgrade it i said ok when they upgraded they were still not able run the gpu more over my mobo is not even able to work without the gpu with the integrated graphics and they are now sayinng that mobo had some fault and that its pci 3.0 slot is not working so you have to change your mobo i asked them to install the previous bios version and show me that it was not any of your fault which caused my mobo any problem so they said come tomowrrow amd it will be ready
i also want to ask that if my pci 3.0 slot was not working then why iwas not getting any trouble in the pas was it becasue that i had no gpu?
thanks and plz help fast
that i had no gpu?
one thing more that they showed me the psu and gpu working on another mobo with my processor and memory
Jose_H_Intel1
Based on your description I suspect the BIOS update caused the system not to be able to POST somehow.
I suggest you checking what BIOS version they used. Since the motherboard had an older BIOS version it is highly recommended to update it incrementally.
Try removing the CMOS battery and power for 20 minutes and then attempt a BIOS recovery.
http://www.intel.com/support/motherboards/desktop/sb/CS-034309.htm Desktop Boards — Computer does not boot after changing BIOS settings
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
It is a good idea checking if you get the expected beeps when the memory is removed.
http://www.intel.com/support/motherboards/desktop/sb/CS-010249.htm Desktop Boards — BIOS Beep Codes
