Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
intel dh87rl bios reset
Community Manager
there is no solution for this board for bios reset any body having solution please provide
Community Manager
Hello, ideaframes:
Thank you for contacting the Intel Communities.
Here you can have some questions that we can answer to troubleshoot this.
1. Are you able to access the BIOS?
2. If that is correct, please check the BIOS version installed in your board.
3. If you are not being able to update the BIOS version, please perform a recovery to the current version and then update to the next version until you reach the desired version.
4. If you are having issues after performing a BIOS update, please perform a recovery to the last version that was installed in your system.
5. In the case were the last version is unknown, you can try with a recovery to the version you attempted to update.
6. Are you having a different issue? Please provide me with a little more detailed explanation of what you are facing so we can continue with the support on this.
Here you can find the instructions on the BIOS recovery: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html
I look forward to hearing from you.
Esteban C
Community Manager
Hello, ideaframes:
Thought I would just check in and find out if you were able to follow the recommended troubleshooting for this.
Esteban C
Community Manager
sir i can't access my system i assign password for admin
how can i recover my old bios version
still my problem is not solved why this board design is very typical for users
we are facing lot of problem nobody provide solution
first you tell how to bypass the password
otherwise i can't recovery old bios
please provide solution quickly
ravi sankar
n_scott_pearson
Super User Retired Employee
Community Manager
i ll try this already but it is not working
n_scott_pearson
Explain what you tried (go step by step if you can) and what actually happened.
Community Manager
Thank you Pearson for the input on this, ideaframes, it would be good to have that information in order to further assist you on this scenario.
Esteban C
Community Manager
Hello, ideaframes:
I was checking this thread and I would like to know if there is any update regarding the information requested previously.
Esteban C
Community Manager
ideaframes :
Just wanted to double check if the issue persisted in your system.
Esteban C
Community Manager
Hey, ideaframes :
I was curious about the outcome you received with this Intel® Desktop Board DH87RL, were you able to perform the BIOS update?
Please let me know :)
Esteban C
