Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
memory upgrade for a D101GGC motherboard
Community Manager
I cannot for the life of me understand the manual for this board, in this case, with regard to the memory supported.
Memory •Two DDR SDRAM Dual Inline Memory Module (DIMM) sockets
•Support for DDR 400 MHz and DDR 333 MHz DIMMs
•Support for up to 2 GB of system memory
Will this support 2 gb of memory or not, if yes exactly what kind is needed?
NOTE
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be
populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows
the BIOS to read the SPD data and program the chipset to accurately configure memory settings
for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly
configure the memory settings, but performance and reliability may be impacted or the DIMMs
may not function under the determined frequency.
Table 4 lists the supported DIMM configurations.
Table 4. Supported Memory Configurations
DIMM
Capacity Configuration
SDRAM
Density
SDRAM Organization
Front-side/Back-side
Number of SDRAM
Devices
128 MB SS 256 Mbit 16 M x 16/empty 4
256 MB SS 256 Mbit 32 M x 8/empty 8
256 MB SS 512 Mbit 32 M x 16/empty 4
512 MB DS 256 Mbit 32 M x 8/32 M x 8 16
512 MB SS 512 Mbit 64 M x 8/empty 8
512 MB SS 1 Gbit 64 M x 16/empty 4
1024 MB DS 512 Mbit 64 M x 8/64 M x 8 16
1024 MB SS 1 Gbit 128 M x 8/empty 8
Note: In the second column, "DS" refers to double-sided memorymodules (containing two rows of SDRAM) and "SS" refers
to single-sided memory modules (containing one row of SDRAM).
I' ve searched for memory with Serial Presence Detect (SPD) data structure but no luck.
Thank you for your help.
Community Manager
Hello Terry,
We would like to inform you that this motherboard will support 1GB on each memory slot, for a total of 2GB maximum for memory system. Since this motherboard was discontinued back in 2008, is really difficult to locate memory rated at the specifications that the board supports due to discontinuance and that memory technologies are constantly evolving.
We recommend getting memory with the following specifications:
- DDR 400 MHz and DDR 333 MHz DIMMs rated at 2.5V
- Non-ECC DIMMs
Further information can be found at the Technical Product Specification page# 15:
http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
Community Manager
Hello Terry,
- Non-ECC DIMMs
