Intel® Desktop Boards
Peer-to-peer support only
mother Dg965ss
FOliv4
El error que me aprece en el mother es el siguiente "The aa Number Has not been Programed on the System "
Pres any key to continue
al intentar actualizar para solucionar el problema el bios con la utilidad de intel
bios exprees me dice que no detecta la versión lo mismo con la version de cd
como puedo actualizar el bios o solucionar el problema agradezco repuestas
n_scott_pearson
Super User Retired Employee
The short answer is that you can not fix this issue. The AA number is programmed in the factory and there is no tool available to restore this in the field. The absence of this number in your BIOS is an indication that corruption has occurred. This could be an indication of a hardware failure (your board is ancient, well past its MTBF date and this is thus not unexpected). Replacing the board is your only option.
Sorry,
Community Manager
Hello all,
federico128, Scott is right; in this case there not much you can do. This error, as mentioned before, indicated a corruption in your BIOS. You could try with a BIOS recovery; however, this will be under your own risk since it might brick the motherboard.
N.Scott.Pearson thank you for the help.
Amy.
