Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
motherboard question
i was just wondering if i could upgrade the motherboard in my compaq SR2150NX with an intel desktop board DP45SG?
Highlighted
Re: motherboard question
Yes,
Any ATX or micro ATX will fit in the compaq case.
It's best to start from scratch then cause, compac's use usual a hidden BIOS partition and that can't be used so remove all partitions
and create new one to install the OS.
If you have never mounted a mainboard before , be carefull for electrostatic discharges.
