Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
msi r9 270x does not work on DP55WB
mstop1
Hi everyone...
I bought a new video card msi r9 270x and install it on my old motherboard intel DP55WB, but when i try to turn on the computer its beeps twice and wont torn on the display.
when ive tried to put back my old card (4870) it works fine.
please help!!
Allan_J_Intel1
Thanks for joining the Desktop Board community.
It appears to be an issue with compatibility. I have checked video cards specifications, the R9 270x is PCI express version 3.0. The motherboard is PCI Express 2.0 and if the new card does not work it may be that this is down clocking to version 2.1. Or, there is a possibility that you need higher power supply.
Allan.
mstop1
Hi allan.
My PSU is seasonic 500w and its fit the recommendation of the card, so i don't think that the problem is here.
What did you mean when you wrote " down clocking to version 2.1"?
Allan_J_Intel1
The version of the PCI Express slot. In this case your motherboard supports 2.0 and your video card 3.0, some of the video cards can down clock the version of the PCI Express revision. But as I mentioned, this might be a compatibility issue because your old video card is working properly.
Allan.
mstop1
As it says herehttp://www.overclockers.co.uk/showproduct.php?prodid=GX-226-MS http://www.overclockers.co.uk/showproduct.php?prodid=GX-226-MS
The card is fully compatible with pcie 2.
So I think it's something with the board!
Maybe there is some BIOS update that I need to install?
Allan_J_Intel1
You could try update BIOS to the latest: 0336
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=21524 Intel® Download Center
Allan.
