Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
my system is not restarting but is able to shutdown and start manully
recently i buy intel dh87mc mother and intel i3 4150 processor and i installed both and try to install desktop drivers and try to reboot it is not rebooting and discard power and start manually please give any solution
Highlighted
Valued Contributor I
First of all here is the list of officially supported processors on that board
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=dh87mc Compatible Processors
Alternatively since the processor is not officially supported you could change it with one on the list above if possible.
Or
Use the method i detailed on the below link
Highlighted
Thank you "stephenb.b.r" your detail instructions were right-on, no more manual power cycle!!
Highlighted
Good to know that the information provided by stephenb.b.r solved your problem.
Regards!
Highlighted
