Community
cancel
Showing results for
Search instead for
Did you mean:
ליאו
plata base - לוח אם
ברשותי מחשב עם לוח אם DH55HC No. BTHC3600HC AA E70933 - 505
מערכת הפעלה נתקעת כבר בהתחלה.
ניסיתי עם  דיסקים שונים כולל הפעלה מדיסק USB.
החלפתי זיכרונות וזה לא עזר
ניתקתי את כל הציוד הנלווה וגם לא עוזר.
הצילו!!!
en mi PC hay placa base DH55HS No. BTHC03600HC AA E70933 - 505
el windows 10 se traba al principio
probe con varios discos sin exito
deconecte todos los implementos no necesarios
AYUDA
LeonWaksman
Hi @ליאו
Since the support in this forum is in English. I'll answer to your post in that language.  I have to admit that although I understand Hebrew well, I can't understand what is your problem? You have to try better to explain it and may be I'll can give you some advice. It is not clear to me if you are trying unsuccessfully install Windows 10 and the installation  stacks or you have installed Windows and it stacks after booting in?
If the problem is during Windows installation, please describe if you can boot from the Installation Media and then you are stack (in this case attach an image of the screen, where the installation is stacked) or, you can't boot at all.
More question - was the Motherboard ever worked? What is the P/N of the RAM, CPU and Storage Drive?
Leon
AlHill
