HI
i' musing deployment tools of micros oft for deploy os
I added netwrok drivers to out of box folder for intel dh61ww motherboard.
when running the deploying gotting error msg about missing drivers
please help me to find the current driver and fix it
WHat to do?
Hi Gil, you may try using the following driver:
https://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=4239 https://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=4239
I found a similar discussion here:
http://social.technet.microsoft.com/Forums/en-US/206fca59-3676-44e0-898c-e09f3f0bb06b/connection-to-... http://social.technet.microsoft.com/Forums/en-US/206fca59-3676-44e0-898c-e09f3f0bb06b/connection-to-...
And the following article:
http://blogs.technet.com/b/askcore/archive/2013/05/09/how-to-manage-out-of-box-drivers-with-the-use-... http://blogs.technet.com/b/askcore/archive/2013/05/09/how-to-manage-out-of-box-drivers-with-the-use-...
I hope this helps.
In those links u sent me,
they using WDS for working with PXE boot.
I dont use WDS server
I boot using winPE disk Image
How to fix it?
The following link lists available drivers for different adapters. I suggest asking Microsoft* regarding the process of loading the necessary drivers so you can complete the deployment. http://www.intel.com/support/network/sb/CS-006120.htm Network Connectivity — Drivers and software for Gigabit Intel® Ethernet Adapters
