Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
question of compatibility between the MB and Memory (ECC RDIMM )
PButy
Hello. I have a question of compatibility between the MB and Memory. Do the MB need to support memory type ECC RDIMM or is it the job of the memory controller in the CPU (xeon)?
Will this bundle work:
1) (motherboards on the b65, h67, b75, h77 and other desktop chipsets) + (xeon CPU)
or it must be
2) (motherboard on the C602..) + (xeon CPU)
Jose_H_Intel1
Most of the Intel® Desktop Boards do not support ECC memory but you can check here:
http://www.intel.com/support/motherboards/desktop/sb/CS-025414.htm Desktop Boards — System Memory Information
