Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
s2600cw2 sever board can't power on
aass
I have my server board s2600cw2 ran in naked environment.
Now I have a problem that the guide book only tells "insert the cables into ssi front panel".
how can I power on it without the cables? The 23 ssi front panel , which one is the power switch ? can I turn it on use one iron key?
Community Manager
You can power on the server by creating a shortcut touching pins 11 and 13 with a screw driver. Further information about the front panel pinout configuration can be found here page # 99:
http://www.intel.com/content/www/us/en/support/server-products/server-boards/000005906.html Technical Product Specification and Specification Update for the Intel® Server Board S2600CW Family
Community Manager
