Community
cancel
Showing results for
Search instead for
Did you mean:
aass
s2600cw2 sever board can't power on
Jump to solution
I have my server board s2600cw2 ran in naked environment.
Now I have a problem that the guide book only tells "insert the cables into ssi front panel".
how can I power on it without the cables? The 23 ssi front panel , which one is the power switch ? can I turn it on use one iron key?
Community Manager
You can power on the server by creating a shortcut touching pins 11 and 13 with a screw driver. Further information about the front panel pinout configuration can be found here page # 99:
http://www.intel.com/content/www/us/en/support/server-products/server-boards/000005906.html Technical Product Specification and Specification Update for the Intel® Server Board S2600CW Family
Community Manager
