Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
scheda madre Intel DH67BL
GDore
Buona sera volevo porre un quesito
la mia scheda madre Intel DH67BL all'avvio mi da il messaggio che non trova nessun Device appare schermo nero è un indirizzo internet intel, non vede il lettore DVD non vede hard disk e neanche le usb, qualche volta riesco ad accedere premendo F10 e scgliendo la periferica, cosa può essere successo ho provato vari hd e anche staccando tutte le periferiche
Grazie
n_scott_pearson
Super User Retired Employee
Try this:
  1. Disconnect system from A/C power.
  2. Remove CR2032 battery from board.
  3. Wait 15 minutes.
  4. Restore battery to board, re-connect to A/C power and power on.
  5. Check results.
Hope this helps,
GDore
Thanks for the answer, I tried to remove the 2032 and Disconnect system from A / C power.
but only for a few seconds and then restarted now or try to leave it disconnected for a little more time
GDore
ho sempre questa risposta non si riesce ad andare avanti, ho fatto quanto consigliato
è possibile una soluzione o è da buttare
Grazie
n_scott_pearson
You need to leave it disconnected for the full 15 minutes; the CMOS power drains slowly.
When you power back on, use F2 to enter BIOS Setup. Then, use F9 to restore the BIOS configuration to defaults. Next, set the date and time. Finally, make any changes in the BIOS configuration that are absolutely necessary for your hardware configuration (i.e. clear CMOS error from log, proper boot order, SATA drive type, etc.). Make sure you save the configuration as you exit BIOS Setup.
In all this, I am presuming that you have already upgraded to the latest available BIOS. If not, you should do so now. Note the following: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005859.html Updating the BIOS to Support 3rd Generation Intel Core Processors.
Hope this helps,
Community Manager
I suggest you to follow N. Scott Pearson recommendations and also to remove every component that you have plugged into your motherboard, RAM, hard drive, power supply, video card etc.
Try you hard drive in different SATA port.
If that does not work there are only a few real possibilities here...
1) Your hard drive controller has failed.
2) Your hard drive's Master Boot Record has failed or been compromised.
3) Your hard drive has physically been damaged.
4) Your power supply is no longer supplying the proper voltage to the drive.
5) Your BIOS has failed or been corrupted.
To find out what the issue is you will need to test your components in another system if it is possible, this is to find out which one is causing the problem.
Ivan
