Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
spdif header for DG41RQ
KPrab1
Hi
I have purchased DG41RQ motherboard it comes with a SPDIF header, intel does not provide connector for the same like to know where i can purchase a optical connector in india. coz i don't seems to find it anywere.
thanks
Adolfo_S_Intel2
Since we do not provide that cable, I would recommend checking sites like:
http://www.cablestogo.com/
http://cablesunlimited.com/
However since you are located in India, you migth want to check with any local computer store to see if they have that cable.
Or you can also check with any Authorized Intel(R) Distributor, please access the following link and select a location, to find the closest authorized distributor:
http://premierlocator.intel.com/Default.aspx
YFern
I purchased a cable and fixed it. but the sound is not coming. please help.
Silvia_L_Intel1
YasithM, I would need to inform you that this motherboard is no longer under support since June 2012. http://www.intel.com/support/motherboards/desktop/sb/CS-033578.htm http://www.intel.com/support/motherboards/desktop/sb/CS-033578.htm
For any audio problems, the following link will provide you the recommended troubleshooting. Also, check if the board needs a BIOS update.
http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm
