Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
starting problem intel dh55tc and i3 540 processor
balex6
my computer does not on.
but inside mother board(dh55tc) shows a green light.
but computer not on.
anyone suggest reason, if smps or motherboard or switch complint. plz
Kevin_M_Intel
Hi bibin,
I am sorry you are having this problems but let me do my best to help you.
There are some troubleshooting steps I would like you to do. Try the following:
  1. Disconnect all components from the motherboard (audio cards, video cards, power supply, etc…) for about 20-30 minutes and then reconnect all components.
  2. If possible test the board in a non-conducted surfaces such s glass or wood to discard grounding issues.
Besides this, when you press the power button, do you see fan activity? Can you try a different power supply?
balex6
no fan activity when pressing power button
Kevin_M_Intel
IF you are getting a green light means that the motherboard is getting power from the power supply.
We can also try to power the board manually (without power button) but I recommend you doing this if you know about the configuration. Here are the steps:
  1. Disconnect the Front Panel Cable from the board
  2. With a coin you can touch pins 6 & 8 from the Front Panel header and this will turn the motherboard on.
See image of front panel connector:
In case you do not feel good doing these steps, I recommend you contacting a technician or a friend of you that may have knowledge of the motherboard hardware.
balex6
Kevin_M_Intel
Hi bibin,
If you have done all the steps mentioned before, tested other power supply and hardware components my best recommendation is to contact your Intel® local support so they can help you with some other steps or replacement if necessary however, keep in mind this unit is a mature product.
balex6
i have replaced my board. its board compliant. thanks
Kevin_M_Intel
