Community
cancel
Showing results for
Search instead for
Did you mean:
Joseph_Rivero
tarjeta madre dh67bl
mi pc cuenta con una tarjeta madre dh67bl tenia una tarjeta grafica el cual se me daño, ahora cuando la enciendo me da los tres pitidos ya que esta arrancando por la pci y no por la gráfica integrada, como puedo hacer para poner la arrancar por la integrada ya que solo me da los tres pitidos Ojo las ram están buenas, gracias por su ayuda
AlHill
Three beeps does indicate a memory error.
Try first reseating the memory.
n_scott_pearson
Super User Retired Employee
If this add-in graphics card is damaged but you've kept is in the system, getting three beeps could be an indication of a problem accessing this add-in graphics card's memory.
If you power on and boot up with the add-in graphics card removed and a monitor connected to one of the motherboard's video connectors, it should automatically use the internal graphics engine. In this case, if you are hearing three beeps, this is a problem with accesses to the system's main memory.
How did this card get damaged? Was it in the system when this happened? If so, a lot more than just the graphics card may have been damaged.
