Community
cancel
Showing results for
Search instead for
Did you mean:
rrich11
trouble installing quad core processor
Jump to solution
Hi All
i have tried to go from a dual core processor to a quad core.
the trouble im having is getting it running.
I have read that the bios needs to be flashed to accept the upgrade?
i have tried using the express bios update from intel but i get the "internal system error" message everytime.
the motherboard is an intel D946GZIS and the processor is an intel core 2 quad q9450
I am running windows xp at the moment
thanks
Richard
AlHill
These are the processors supported by your motherboard:
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=D946GZIS Compatible Processors
There are no quad core processors supported on your board. There is no bios update that will help you.
I would stop now and revert to your previous processor. It is possible that what you are doing could damage your motherboard.
Also, this is your board: http://ark.intel.com/products/23503/Intel-Desktop-Board-D946GZIS Intel® Desktop Board D946GZIS Specifications It is 10 years old and no longer supported.
This is the processor you are trying to use: http://ark.intel.com/products/33923/Intel-Core2-Quad-Processor-Q9450-12M-Cache-2_66-GHz-1333-MHz-FSB Intel® Core™2 Quad Processor Q9450 (12M Cache, 2.66 GHz, 1333 MHz FSB) Specifications It is 8 years old, and no longer supported.
While the board has socket 775, and the processor uses socket 775, the part that is missing is BIOS support of the processor. Any upgrade processor must be socket and BIOS compatible.
Doc
AlHill
Doc
n_scott_pearson
Super User Retired Employee
In that processor generation, the quad-core processors actually utilized two dual-core processor dies. As a result, their power requirements were significantly higher than that for dual-core processors (which utilized only a single die). If the board does not list support for quad-core processors, it is likely because the board's voltage regulators cannot provide all of the power necessary. Keeping this processor in the system for any length of time could result in the burnout of the voltage regulators (a non-repairable situation).
I realize that you are likely attempting the upgrade the processor in an effort to keep this older system alive and relevant. IMHO, you are throwing good money after bad. This board is well beyond its (typically 7 year) MTBF and component failures could begin to occur at any time (if they haven't already). I think its time for you to consider replacing this system...
Hope this helps,
Community Manager
Hello:
Thank you very much to Al Hill and N. Scott Pearson for the comments posted previously.
To dannyboy:
I just wanted to confirm the information above as correct, as it was mentioned the processor that you are trying to use is not compatible with your motherboard, but you can always choose any of the processors that are showing on the compatibility list.
Alberto
