Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
turn on 2 seconds?
GPiza
Hello. I bought it on amazon as follows: Intel i7 4770k 3.5 gh ; Intel dz87klt - 75k ; Intel Motherboard Liquid Cooler - BXTS13X Fsp pro aurum 850 w . And other things. When assembling pc , lights up for 2 seconds and off ; and so on until I turn off the power supply . A red LED that indicates that the cpu is hot lights. The probe without devices have the same result Any ideas ?
Silvia_L_Intel1
Hello Gaprios, thanks for joining the Intel communities.
These are some troubleshooting steps you can follow for this kind of behavior:
If you have access to another system, please check the following link http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm Desktop Boards — No Boot Troubleshooting Wizard
GPiza
Thanks Sylvia.
I did it. Keep doing the same. The battery is good. I think in any conflict with integrated video. O at power and reset.
KBenm
cpu hot? imho you're f****d... either disassembling/reassembling works, or you have a bad mobo like I did. see here:
there seems to be quite a lot of problems with this board btw...
GPiza
Thanks for your reply . my components are new. They made the mistake of selling defective products and only touches me try some specialized technician to fix the motherboard. And buy an amd soon.
Silvia_L_Intel1
Gaprios, if you are still having problems and you prefer replacing the processor or the motherboard, you can get in touch with our Warranty team http://www.intel.com/p/en_US/support/contactsupport Contact Support or submit a web ticket at the following URL https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us Service Request Email
Bear in mind that if the products were purchase less than one month ago, it will be necessary to contact the place of purchase.
GPiza
Gracias por responder. Efectue la consulta correspondiente y me hicieron el cambio de la placa. Hace una semana me llego la placa similar y la lleve al tecnico para que la integrara. Pero, me indica que ya no hace el "prender y apagar". No puede prenderlo, no hace sonido y no emite ninguna señal. Esta buscando la forma de integrar ese equipo. Y me pregunto: No hay en Caracas una empresa INTEL que pueda solucionar estos problemas de integracion que tiene la placa? Porque he visto muchos comentarios y su funcionamiento indica que es espectacular. En mi caso, aun no puedo encenderla. Y tengo otros dos procesadores i7-4770K que deseo hacerlos funcionar ya.
Silvia_L_Intel1
Gaprios el numero de telefono de Intel en Venezuela es el siguiente:0800 102 9142
Gracias
