Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
unknown intel mobo - driver can't get
Community Manager
please help me successfully load driver for intel mobo device "unknown"
board is called "can't collect info"
maybe CD drivers necessary for this intel board?
Silvia_L_Intel1
Hewo, would you please check for a white sticker label inside of the motherboard, it is going to provide you an AA# ?
Here is how it looks like: http://www.intel.com/support/motherboards/desktop/sb/cs-010687.htm Desktop Boards — Identify your desktop board
You can also send me a picture.
Community Manager
Desktop Board Information
Manufacturer Intel Corporation
Product Name D975XBX
Version AAD27094-306
Serial Number BQBX648001NC
from BIOS (too much humbug visual actual board sticker, eyes are old age sight capacity)
Community Manager
i sent an answer to you by replying but it is not visible posted - strange site
Silvia_L_Intel1
This link provided all drivers, BIOS versions and software available for your motherboard. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine... Download Center
It is very important for you to know that this motherboard has been out of support since June 2010 http://www.intel.com/support/motherboards/desktop/sb/CS-029308.htm Desktop Boards — End of interactive support announcement
Community Manager
thanks sylvia
been there in 2010 and 2011 so drivers have not changed at all.
the board features fault tolerance (RAID) hardware and i think that's why a driver does not load - see pic attached
Silvia_L_Intel1
Hewo, it is very important to install the drivers in order, beginning with the chipset driver (.INF), graphics, audio and then management engine.
I would recommend you to install all drivers and OS with the motherboard out of chassis. Also use minimum configuration such as motherboard, processor, 1 memory stick, power supply and video card.
Remember that this motherboard supports only Windows XP and 2000 operating systems. http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported operating systems
