Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
whether DH55HC supports windows 7 64bit
NKund
I have DH55HC Intel motherboard with bios version Intel Corp. TCIBX10H.86A.0035.2010.0429.1516.I am not able to install any windows operating system using SONY DVD RW DRU-870S ATA Device .I have connected same hard disk and dvd writer to asus motherboard with same dvd window 7 32 bit..Iam able to format .Is there any issue with bios
Jose_H_Intel1
You can review the BIOS settings here: http://www.intel.com/support/motherboards/desktop/sb/CS-020304.htm Desktop Boards — BIOS Settings Glossary
Did you try connecting the optical drive to a different black SATA port?
NKund
Hi Joe,
Thanks for your reply..
I guess issue is with Ram.I have removed 4 GB ram which is having speed of 1600Mhz installed in channel b dimm1 .After removing ram I am able to install windows 7 64 bit operating system .currently there is only one ram which is 2 gb with speed 1333mhz in channel a dimm 0.
could you please update me whether this mother board supports 4 gb ram with 1600mhz speed.Please provide me the document which contains proper way to place ram in motherboard.
Jose_H_Intel1
Please check the following articles and compare the motherboard memory requirements with the specifications of the memory you have or plan to get.
http://www.intel.com/support/motherboards/desktop/sb/CS-008326.htm Desktop Boards — Supported Operating Systems
http://www.intel.com/support/motherboards/desktop/dh55hc/sb/CS-030953.htm Intel® Desktop Board DH55HC — System Memory
NKund
It was issue with ram frequency.. I bought new ram with frequency 1333mhz ,It is working fine.
