Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
How to access the DevCloud for Edge through ssh
Jerry_J
This is Jerry in the TES/PMCE/IOTG.
I am trying the connect through the terminal of Ubuntu 18.04 to DevCloud.
I found the solutions in this community, but it based on the OneAPI DevCloud.
ex) https://community.intel.com/t5/Intel-DevCloud/cannot-Connect-from-Linux-SSH/m-p/1143497#M317
So, I wonder about the method to connect the DevCloud for Edge using ssh on Ubuntu.
Can you help me to find the reference guide for that method for the DevCloud for Edge?
For example, how to get the Colfax key for the DevCloud for Edge? or is it the same method on the OneAPI DevCloud?
Jerry
Andrey_Vladimirov
New Contributor III
Hi Jerry,
For Intel DevCloud for the Edge users, SSH connection from the outside is not supported.
If you don't need to be connected from the outside but just need a terminal, you can get it inside a web browser: launch the Jupyter server, and then click New->Terminal: https://devcloud.intel.com/edge/resource_docs/development_environment/#linux-terminal
Andrey
Andrey_Vladimirov
New Contributor III
Hi Jerry,
Andrey
JesusE_Intel
