Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1709 Discussions
无法使用vscode连接devcloud
MarsPJ
无法使用vscode连接到devcloud,window10,连接错误界面为:
配置文件内容为:
JaideepK_Intel
I hope you are doing well.
One of our team mates contacted you privately and shared some details, can we go ahead and close this case?
Jaideep
JaideepK_Intel
Thank you for posting in intel communities. We only provide support in English. I have translated your question.
>>Unable to use vscode to connect to devcloud, window10, the connection error interface is:
Does this reflect your question correctly?
If yes means, could you please share screenshots of error in english.
Jaideep
JaideepK_Intel
Thanks for sharing the screenshot, Please modify your config file as shown below.
# DevCloud VSCode config
Host devcloud-vscode
 UserKnownHostsFile /dev/null
 StrictHostKeyChecking no
 HostName localhost
 User uxxxxxx
 Port 4022
 IdentityFile ~/.ssh/devcloud-access-key-xxxxxx.txt
 ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-xxxxxx.txt guest@ssh.devcloud.intel.com
Please change the port number to 4022 and also add the proxy command as shown above. After modifying the config file try to connect to devcloud. (looks like below screenshot after a successful connection)
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
MarsPJ
I couldn't connect to devcloud even after I changed the config file
JaideepK_Intel
Can you please go to the below link and check whether you can access jupyter notebook or not? Also, check if your account is expired or not from the same link.
link: https://devcloud.intel.com/oneapi/get_started/
Jaideep
MarsPJ
It can be accessed normally and has not expired
JaideepK_Intel
From the above error, we can assume that the path to the key may be wrong or key might be corrupted or the key may not have enough permissions.
error:
file permissions for .ssh and for config:
Jaideep
MarsPJ
On windows, I checked the.ssh and config permissions, and they are the same as your instance. As a side note, I also get Permission denied (publickey) when I try to connect directly with ssh on linux (without vscode).
MarsPJ
Does this have anything to do with me being a user in China? But I can't even hang up VPN
MarsPJ
Does this have anything to do with me being a user in China? But I couldn't connect to devcloud even through VPN
JaideepK_Intel
One of our teammates is going to share the devcloud key privately. Please change the current key with the new key and try the same from your end. Please let us know if the issue still persists.
Jaideep
JaideepK_Intel
Can we go ahead and close this thread? or if you still face the issue please let us know.
Jaideep
MarsPJ
I tried to use the new key you provided, but it still shows the same error. In addition, since the deadline of Hackfair is approaching, I choose to use jupyter lab provided by you for development now, and I want to ignore ssh. Thank you for your help!
JaideepK_Intel
Can you please remove (rm - rf ~/.ssh/known_hosts) the file with the name know_hosts in ~/.ssh path and try again?
Please check ~/.ssh directory permissions as well.
chmod 600 ~/.ssh/devcloud-access-uxxxxxx.txt
chmod 600 ~/.ssh/config
Jaideep
MarsPJ
JaideepK_Intel
For windows it will be there in the below directory.
default directory: C:\Users\<user_name>\.ssh
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
Good day to you
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
