Hi, Here are the full steps.
Build Container:
[build@cliservice-devcloud-prc-1-v8ztr benchmark]$ cd ..
[build@cliservice-devcloud-prc-1-v8ztr python]$ cd ..
[build@cliservice-devcloud-prc-1-v8ztr developer-samples]$ cd ..
[build@cliservice-devcloud-prc-1-v8ztr openvino-dev-latest]$ buildah bud --format docker -f ./developer-samples/python/benchmark/dockerfile/ubuntu18/openvino_cgvh_dev_2021.4.dockerfile -t $REGISTRY_URL/benchmark:custom .
STEP 1: FROM openvino/ubuntu18_data_dev:2021.4.2 Getting image source signatures Copying blob 284055322776 done Copying blob b4d712e1f2f6 done Copying blob 2afa30e87146 done Copying blob 54565d5ea21d done Copying blob b723bca72249 done Copying blob fd749a448545 done Copying blob 54130385d437 done Copying blob 49e3cfef4f14 done Copying blob b4fd570631e4 done Copying blob 5bfcc6a17f60 done Copying blob 29293e22bbed done Copying blob 185f7445ce77 done Copying blob f9fbcb911af2 done Copying blob 947517d6524d done Copying blob c485fb3156de done Copying blob 968ab1b03478 done Copying blob fefd75b6e450 done Copying blob 144d11e956f2 done Copying blob 240a416b23c6 done Copying blob 901cda405aa2 done Copying blob 622431bef8f1 done Copying blob f7a232120e00 done Copying blob b04a497a37d7 done Copying blob 93847378b4c4 done Copying config 3e3f6224f4 done Writing manifest to image destination Storing signatures
STEP 2: RUN echo "OpenVINO installation done ......." + echo 'OpenVINO installation done .......' OpenVINO installation done .......
STEP 3: RUN echo ${INTEL_OPENVINO_DIR} + echo /opt/intel/openvino /opt/intel/openvino STEP 4: USER root
STEP 5: RUN echo "Intel devcloud benchmak sample containerization begin ......." + echo 'Intel devcloud benchmak sample containerization begin .......' Intel devcloud benchmak sample containerization begin .......
STEP 6: RUN chmod 777 ${INTEL_OPENVINO_DIR}/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites.sh + chmod 777 /opt/intel/openvino/deployment_tools/model_optimizer/install_prerequisites/install_prerequisites.sh
STEP 7: RUN mkdir -p ${INTEL_OPENVINO_DIR}/python/samples + mkdir -p /opt/intel/openvino/python/samples
STEP 8: ADD developer-samples/python/benchmark ${INTEL_OPENVINO_DIR}/python/samples/benchmark
STEP 9: ADD developer-samples/python/benchmark/benchmark ${INTEL_OPENVINO_DIR}/python/python3.7/openvino/tools/benchmark
STEP 10: ADD developer-samples/python/benchmark/benchmark ${INTEL_OPENVINO_DIR}/python/python3.6/openvino/tools/benchmark
STEP 11: COPY developer-samples/python/benchmark/main.py ${INTEL_OPENVINO_DIR}/python/python3.7/openvino/tools/benchmark/main.py
STEP 12: COPY developer-samples/python/benchmark/main.py ${INTEL_OPENVINO_DIR}/python/python3.6/openvino/tools/benchmark/main.py
STEP 13: COPY developer-samples/python/benchmark/benchmark.sh ${INTEL_OPENVINO_DIR}/python/samples/benchmark
STEP 14: RUN chmod 777 ${INTEL_OPENVINO_DIR}/deployment_tools/model_optimizer/mo.py + chmod 777 /opt/intel/openvino/deployment_tools/model_optimizer/mo.py
STEP 15: RUN chmod -R 777 ${INTEL_OPENVINO_DIR}/python/samples + chmod -R 777 /opt/intel/openvino/python/samples
STEP 16: ENV PATH ${INTEL_OPENVINO_DIR}/python/samples:$PATH
STEP 17: ARG DEVICE="CPU"
STEP 18: ENV DEVICE=$DEVICE
STEP 19: ARG PRECISION="FP16"
STEP 20: ENV PRECISION="$PRECISION"
STEP 21: ARG OPENVINO_VERSION="2022.1.0.643"
STEP 22: ENV OPENVINO_VERSION=$OPENVINO_VERSION
STEP 23: ARG OUTPUT_FOLDER="output_benchmark_app_latest"
STEP 24: ENV OUTPUT_FOLDER=$OUTPUT_FOLDER
STEP 25: ARG SUPPORTED_HW="CPU_TDP_70_205W"
STEP 26: ENV SUPPORTED_HW=$SUPPORTED_HW
STEP 27: ARG RUN_ON_PREM="/mount_folder"
STEP 28: ENV RUN_ON_PREM=$RUN_ON_PREM
STEP 29: RUN source ${INTEL_OPENVINO_DIR}/bin/setupvars.sh + source /opt/intel/openvino/bin/setupvars.sh ++++ dirname /opt/intel/openvino/bin/setupvars.sh +++ cd /opt/intel/openvino/bin +++ pwd ++ SCRIPT_DIR=/opt/intel/openvino/bin +++ dirname /opt/intel/openvino/bin ++ BASE_DIR=/opt/intel/openvino ++ INSTALLDIR=/opt/intel/openvino ++ export INTEL_OPENVINO_DIR=/opt/intel/openvino ++ INTEL_OPENVINO_DIR=/opt/intel/openvino ++ export INTEL_CVSDK_DIR=/opt/intel/openvino ++ INTEL_CVSDK_DIR=/opt/intel/openvino ++ [[ 0 -gt 0 ]] ++ '[' -e /opt/intel/openvino/deployment_tools/inference_engine ']' ++ export InferenceEngine_DIR=/opt/intel/openvino/deployment_tools/inference_engine/share ++ InferenceEngine_DIR=/opt/intel/openvino/deployment_tools/inference_engine/share +++ ls /opt/intel/openvino/deployment_tools/inference_engine/lib/ ++ system_type=intel64 ++ IE_PLUGINS_PATH=/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ [[ -e /opt/intel/openvino/deployment_tools/inference_engine/lib/intel64/arch_descriptions ]] ++ export HDDL_INSTALL_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/hddl ++ HDDL_INSTALL_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/hddl ++ [[ linux-gnu == \d\a\r\w\i\n* ]] ++ export LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ HDDL_UNITE_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/hddl_unite ++ '[' -e /opt/intel/openvino/deployment_tools/inference_engine/external/hddl_unite ']' ++ '[' -e /opt/intel/openvino/deployment_tools/inference_engine/external/tbb ']' ++ [[ linux-gnu == \d\a\r\w\i\n* ]] ++ export LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ export TBB_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/cmake ++ TBB_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/cmake ++ '[' -e /opt/intel/openvino/deployment_tools/ngraph ']' ++ export LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ LD_LIBRARY_PATH=/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ export ngraph_DIR=/opt/intel/openvino/deployment_tools/ngraph/cmake ++ ngraph_DIR=/opt/intel/openvino/deployment_tools/ngraph/cmake ++ '[' -e /opt/intel/openvino/opencv ']' ++ '[' -f /opt/intel/openvino/opencv/setupvars.sh ']' ++ source /opt/intel/openvino/opencv/setupvars.sh +++ export OpenCV_DIR=/opt/intel/openvino/opencv/cmake +++ OpenCV_DIR=/opt/intel/openvino/opencv/cmake +++ export LD_LIBRARY_PATH=/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 +++ LD_LIBRARY_PATH=/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++ '[' -f /opt/intel/openvino/data_processing/dl_streamer/bin/setupvars.sh ']' ++ source /opt/intel/openvino/data_processing/dl_streamer/bin/setupvars.sh +++ DATA_PROCESSING_DIR=/opt/intel/openvino/data_processing +++ source /opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-setupvars.sh ++++ DATA_PROCESSING_DIR=/opt/intel/openvino/data_processing ++++ PREFIX=/opt/intel/openvino/data_processing/gstreamer ++++ LIBDIR=/opt/intel/openvino/data_processing/gstreamer/lib ++++ LIBEXECDIR=/opt/intel/openvino/data_processing/gstreamer/bin ++++ GSTREAMER_EXECUTABLES_DIR=/opt/intel/openvino/data_processing/gstreamer/bin:/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0 ++++ [[ ! :: == *\:\/\o\p\t\/\i\n\t\e\l\/\o\p\e\n\v\i\n\o\/\d\a\t\a\_\p\r\o\c\e\s\s\i\n\g\/\g\s\t\r\e\a\m\e\r\/\l\i\b\/\g\s\t\r\e\a\m\e\r\-\1\.\0\:* ]] ++++ export GST_PLUGIN_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0 ++++ GST_PLUGIN_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0 ++++ export PATH=/opt/intel/openvino/data_processing/gstreamer/bin:/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0:/opt/intel/openvino/python/samples:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++++ PATH=/opt/intel/openvino/data_processing/gstreamer/bin:/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0:/opt/intel/openvino/python/samples:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++++ export LIBRARY_PATH=/opt/intel/openvino/data_processing/gstreamer/lib: ++++ LIBRARY_PATH=/opt/intel/openvino/data_processing/gstreamer/lib: ++++ export LD_LIBRARY_PATH=/opt/intel/openvino/data_processing/gstreamer/lib:/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++++ LD_LIBRARY_PATH=/opt/intel/openvino/data_processing/gstreamer/lib:/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 ++++ export PKG_CONFIG_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/pkgconfig: ++++ PKG_CONFIG_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/pkgconfig: ++++ export GI_TYPELIB_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/girepository-1.0 ++++ GI_TYPELIB_PATH=/opt/intel/openvino/data_processing/gstreamer/lib/girepository-1.0 ++++ export PYTHONPATH=/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++++ PYTHONPATH=/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++++ export GST_PLUGIN_SCANNER=/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0/gst-plugin-scanner ++++ GST_PLUGIN_SCANNER=/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0/gst-plugin-scanner +++ PREFIX=/opt/intel/openvino/data_processing/dl_streamer +++ LIBDIR=/opt/intel/openvino/data_processing/dl_streamer/lib +++ [[ ! :/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0: == *\:\/\o\p\t\/\i\n\t\e\l\/\o\p\e\n\v\i\n\o\/\d\a\t\a\_\p\r\o\c\e\s\s\i\n\g\/\d\l\_\s\t\r\e\a\m\e\r\/\l\i\b\:* ]] +++ export GST_PLUGIN_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0 +++ GST_PLUGIN_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib/gstreamer-1.0 +++ export LD_LIBRARY_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib:/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 +++ LD_LIBRARY_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib:/opt/intel/openvino/opencv/lib:/opt/intel/openvino/deployment_tools/ngraph/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/lib::/opt/intel/openvino/deployment_tools/inference_engine/external/hddl/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/omp/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/gna/lib:/opt/intel/openvino/deployment_tools/inference_engine/external/mkltiny_lnx/lib:/opt/intel/openvino/deployment_tools/inference_engine/lib/intel64 +++ export LIBRARY_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib: +++ LIBRARY_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib:/opt/intel/openvino/data_processing/gstreamer/lib: +++ export PKG_CONFIG_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib/pkgconfig:/opt/intel/openvino/data_processing/gstreamer/lib/pkgconfig: +++ PKG_CONFIG_PATH=/opt/intel/openvino/data_processing/dl_streamer/lib/pkgconfig:/opt/intel/openvino/data_processing/gstreamer/lib/pkgconfig: +++ export PYTHONPATH=/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: +++ PYTHONPATH=/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: +++ export GST_SAMPLES_DIR=/opt/intel/openvino/data_processing/dl_streamer/samples +++ GST_SAMPLES_DIR=/opt/intel/openvino/data_processing/dl_streamer/samples +++ export MODELS_PATH=/root/intel/dl_streamer/models +++ MODELS_PATH=/root/intel/dl_streamer/models +++ export LC_NUMERIC=C +++ LC_NUMERIC=C ++ export PATH=/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/gstreamer/bin:/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0:/opt/intel/openvino/python/samples:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ PATH=/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/gstreamer/bin:/opt/intel/openvino/data_processing/gstreamer/bin/gstreamer-1.0:/opt/intel/openvino/python/samples:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin ++ export PYTHONPATH=/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ PYTHONPATH=/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ '[' -e /opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker ']' ++ export PYTHONPATH=/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ PYTHONPATH=/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ '[' -e /opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit ']' ++ export PYTHONPATH=/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ PYTHONPATH=/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ '[' -z '' ']' +++ python3 -c 'import sys; print(str(sys.version_info[0])+"."+str(sys.version_info[1]))' ++ python_version=3.6 ++ OS_NAME= ++ command -v lsb_release +++ python3 -c 'import sys; print(64 if sys.maxsize > 2**32 else 32)' ++ python_bitness=64 ++ '[' 64 '!=' '' ']' ++ '[' 64 '!=' 64 ']' ++ MINIMUM_REQUIRED_PYTHON_VERSION=3.6 +++ [[ linux-gnu == \d\a\r\w\i\n* ]] +++ echo 3.8 ++ MAX_SUPPORTED_PYTHON_VERSION=3.8 ++ [[ -n 3.6 ]] +++ printf '%s\n' 3.6 3.6 +++ sort -V +++ head -n 1 ++ [[ 3.6 != \3\.\6 ]] ++ '[' -n 3.6 ']' ++ [[ -d /opt/intel/openvino/python ]] ++ export PYTHONPATH=/opt/intel/openvino/python/python3:/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ PYTHONPATH=/opt/intel/openvino/python/python3:/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ pydir=/opt/intel/openvino/python/python3.6 ++ [[ -d /opt/intel/openvino/python/python3.6 ]] ++ export PYTHONPATH=/opt/intel/openvino/python/python3.6:/opt/intel/openvino/python/python3:/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ PYTHONPATH=/opt/intel/openvino/python/python3.6:/opt/intel/openvino/python/python3:/opt/intel/openvino/deployment_tools/tools/post_training_optimization_toolkit:/opt/intel/openvino/deployment_tools/open_model_zoo/tools/accuracy_checker:/opt/intel/openvino/deployment_tools/model_optimizer:/opt/intel/openvino/data_processing/dl_streamer/python:/opt/intel/openvino/data_processing/gstreamer/lib/python3.8/site-packages: ++ echo '[setupvars.sh] OpenVINO environment initialized' [setupvars.sh] OpenVINO environment initialized ++ export TBB_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/cmake ++ TBB_DIR=/opt/intel/openvino/deployment_tools/inference_engine/external/tbb/cmake
STEP 30: RUN echo "Generating OpenVINO IR files ......." + echo 'Generating OpenVINO IR files .......' Generating OpenVINO IR files .......
STEP 31: RUN echo "Executing Benchmarking app using OpenVINO latest ......." + echo 'Executing Benchmarking app using OpenVINO latest .......' Executing Benchmarking app using OpenVINO latest .......
STEP 32: WORKDIR ${INTEL_OPENVINO_DIR}/python/samples/benchmark
STEP 33: ENTRYPOINT /bin/bash -c "source ${INTEL_OPENVINO_DIR}/python/samples/benchmark/benchmark.sh"
STEP 34: COMMIT default-route-openshift-image-registry.apps.prc.cfa.devcloud.intel.cn/luohye25-intel/benchmark:custom Getting image source signatures Copying blob 824bf068fd3d skipped: already exists Copying blob 1318a9bb5a3d skipped: already exists Copying blob 8ebe8bf9a7b6 skipped: already exists Copying blob d86ca7bc5879 skipped: already exists Copying blob b4f084753f69 skipped: already exists Copying blob 2aec5cff3cb4 skipped: already exists Copying blob 856b54a0503d skipped: already exists Copying blob b221f9ac4002 skipped: already exists Copying blob 79b4a8921115 skipped: already exists Copying blob 76913aae488a skipped: already exists Copying blob 4d2b2bc25ec6 skipped: already exists Copying blob ad2ec6be5093 skipped: already exists Copying blob f1d1336405c5 skipped: already exists Copying blob 73de2d3a04c5 skipped: already exists Copying blob 8403c928936c skipped: already exists Copying blob 83ecd8916241 skipped: already exists Copying blob 9b690cc54925 skipped: already exists Copying blob 7b4ee1a88472 skipped: already exists Copying blob afc4670a56c8 skipped: already exists Copying blob 4cbd30c0f629 skipped: already exists Copying blob 869cbed038d4 skipped: already exists Copying blob 387269beb2c2 skipped: already exists Copying blob 4158296d9215 skipped: already exists Copying blob 75de083c1f7e skipped: already exists Copying blob 527d4a6dd47d done Copying config bb467e16f8 done Writing manifest to image destination Storing signatures --> bb467e16f85 bb467e16f8540bb68661feabb285a3bd0d725f2c3d17b700b89a520f8b506a30 Push to
Private Registry:
[build@cliservice-devcloud-prc-1-v8ztr openvino-dev-latest]$ buildah tag $REGISTRY_URL/benchmark:custom $REGISTRY_URL/benchmark:custom
[build@cliservice-devcloud-prc-1-v8ztr openvino-dev-latest]$ buildah push $REGISTRY_URL/benchmark:custom Getting image source signatures
Copying blob 1318a9bb5a3d done
Copying blob 8ebe8bf9a7b6 done
Copying blob 2aec5cff3cb4 done
Copying blob b4f084753f69 done
Copying blob 824bf068fd3d done
Copying blob d86ca7bc5879 done
Copying blob b221f9ac4002 done
Copying blob 79b4a8921115 done
Copying blob 856b54a0503d done
Copying blob 4d2b2bc25ec6 done
Copying blob ad2ec6be5093 done
Copying blob 76913aae488a [================>---------------------] 1.8GiB / 3.9GiB
Copying blob 73de2d3a04c5 [--------------------------------------] 8.0b / 160.5KiB
Copying blob f1d1336405c5 [--------------------------------------] 8.0b / 5.0KiB
Copying blob 8403c928936c [--------------------------------------] 8.0b / 55.5KiB
Copying blob 83ecd8916241 [--------------------------------------] 8.0b / 46.5KiB
Copying blob 9b690cc54925 done
Copying blob 83ecd8916241 done
Copying blob 7b4ee1a88472 done
Copying blob 73de2d3a04c5 done
Copying blob f1d1336405c5 done
Copying blob 8403c928936c done
Copying blob afc4670a56c8 done
Copying blob 4cbd30c0f629 done
Copying blob 869cbed038d4 done
Copying blob 387269beb2c2 done
Copying blob 4158296d9215 done
Copying blob 75de083c1f7e done
error pushing image "default-route-openshift-image-registry.apps.prc.cfa.devcloud.intel.cn/luohye25-intel/benchmark:custom" to "docker://default-route-openshift-image-registry.apps.prc.cfa.devcloud.intel.cn/luohye25-intel/benchmark:custom": error copying layers and metadata from "containers-storage:[vfs@/home/build/.local/share/containers/storage+/var/tmp/1000/containers]default-route-openshift-image-registry.apps.prc.cfa.devcloud.intel.cn/luohye25-intel/benchmark:custom" to "docker://default-route-openshift-image-registry.apps.prc.cfa.devcloud.intel.cn/luohye25-intel/benchmark:custom": Error trying to reuse blob sha256:824bf068fd3dc3ad967022f187d85250eb052f61fe158486b2df4e002f6f984e at destination: failed to read from destination repository luohye25-intel/benchmark: 504 (Gateway Timeout) ERRO exit status 1
