Hi team,
This morning I couldn't connect to devcloud via VS Code. I have been trying some of the solutions proposed in the forum, but none of them worked.
Through the terminal I could access devcloud using ssh, but it took longer than usual to establish the connection.
I went back to VS Code and increased the timeout of the ssh extension. This did solve the problem.
I'm just posting this here in case someone else is in the same situation while the team troubleshoots the problem.
I hope it helps!
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information,
please post a new question as this thread will no longer be monitored by Intel.
Shyam Sundar
Shyam Sundar
