Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
About FPGA SDK for OpenCL in devcloud
yyjpro
Can FPGA SDK for OpenCL be used in devcloud? In the get started guide of oneAPI, OpenCL for FPGA development is an oneAPI toolkit. I want to test some OpenCL code before using DPC++. I simply tested a case, which shows the following errors. Is there a solution or other guidance? Thanks.
uxxxx@s001-n013:~$ gcc Template.cpp
Template.cpp:3:10: fatal error: CL\opencl.h: No such file or directory
    3 | #include "CL\opencl.h"
compilation terminated.
VaradJ_Intel
Yes, You can use FPGA SDK for OpenCL in DevCloud.
For more information, Please check the links given below:
https://devcloud.intel.com/oneapi/
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-guidance/opencl-software-support.html
Please can you try compiling your code using dpcpp compiler.
You can compile it using the below command line:
dpcpp Template.cpp
If the issue still persists, please share the sample reproducer to try out the same from our end.
Thank You.
VaradJ_Intel
We have not heard back from you.
Could you please give us an update?
Thank you.
VaradJ_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thank You.
