Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1717 Discussions
About migration
dev_uer123
Hello, developer, do you have any function upgrades or new functions besides security after the deactivation after February 12?
Rahila_T_Intel
Please find the below changes after migration to support enhanced security controls.
Highlights
  • We are moving our digital experiences to a new sign in and authentication process through Microsoft Azure AD*
What’s Changing
New Sign In Process
  • You will be prompted to provide your individual email address to identify yourself - user names or shared email addresses will no longer be accepted
  • You may also be asked to change your password
If you are accessing proprietary content, the system will prompt you to set up a Multifactor Authentication (MFA) process
  • You will need your phone & email to complete the process
  • Going forward, you will utilize the MFA process each time you sign in
For reference :
https://www.intel.com/content/www/us/en/support/topics/azure-sign-in.html
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Rahila_T_Intel
Thanks for posting in Intel communities.
We are checking on this internally and will share you the updates.
dev_uer123
Rahila_T_Intel
Highlights
What’s Changing
New Sign In Process
For reference :
Rahila_T_Intel
We haven't heard back from you. Could you please give us an update?
Rahila_T_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
dev_uer123
hi moderator, you have solved the problem which I have posted. Thanks a lot.
