Hi there,
I'm trying to access the S10 on the devcloud but I am getting the following message
qsub: submit error (Unauthorized Request MSG=group ACL is not satisfied:
When I run the groups command I get the following
c009
Not sure if I need to be added to another group?
Thank you for providing the information. You’re indeed working in OneAPI devcloud.
> The error is related to qsub. Inorder to access stratix 10 in devcloud , ensure that you are executing the following command so that you can access any available node having stratix 10.
qsub -I -l nodes=1:stratix10:ppn=2 //(first is caps ‘i’ then small ‘L’)
> No need to add you to another group.
For more information, please refer https://devcloud.intel.com/oneapi/documentation/job-submission/ . Hope this helps you.
Gopika
Thank you for posting in Intel Devcloud forum. Could you please specify whether you are using OneAPI devcloud or FPGA devcloud? This forum is dedicated for OneAPI devcloud related queries. We have a dedicated forum for FPGA related queries. Please post your query in https://community.intel.com/t5/Intel-High-Level-Design/bd-p/high-level-design if you are using FPGA devcloud.
Gopika
Hi Gopika,
I am using OpenCL on the devcloud. I'll post this issue over there instead.
Thanks!
Thank you for the update. We have OpenCL in both OneAPI and FPGA devcloud. Inorder to support you further, could you please confirm from which link you’ve registered for devcloud
1. FPGA: https://software.intel.com/content/www/us/en/develop/tools/devcloud/fpga.html
It has the leading FPGA hardware with tools optimized for Intel® technology.
2. OneAPI: https://devcloud.intel.com/oneapi/
The Intel DevCloud is a data center grade cluster that allows you to develop and test your projects with the Intel OneAPI based toolkits.
Gopika
Hi Gopika,
I can't actually remember from which link I used to register but my Unique Access URL: https://devcloud.intel.com/one
And OneAPI is mentioned a lot in that email....
Gopika
Thank you for accepting it as a solution. We are assuming your issue is resolved, so we are discontinuing monitoring this thread. For further issue and queries, please raise a new thread. We’d be happy to help you.
Gopika
