Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
Accessing node with a 4th Gen Intel Xeon
L30nardo
Hi, based on the announcement made on Jan 11 2023, I would like to access a node hosting such processors. Which device name corresponds to a 4th Gen Xeon?
I can see the node properties, but I don't know which corresponds to a 4th Gen Xeon:
$ pbsnodes | sort | grep properties
properties = core,tgl,i9-11900kb,ram32gb,netgbe,gpu,gen11
properties = xeon,cfl,e-2176g,ram64gb,net1gbe,gpu,gen9
properties = xeon,clx,ram192gb,net1gbe,batch,extended,fpga,stratix10,fpga_runtime
properties = xeon,icx,gold6348,ramgb,netgbe,jupyter,batch
properties = xeon,icx,plat8380,ram2tb,net1gbe,batch
properties = xeon,skl,gold6128,ram192gb,net1gbe,fpga_runtime,fpga,arria10
properties = xeon,skl,gold6128,ram192gb,net1gbe,jupyter,batch
properties = xeon,skl,gold6128,ram192gb,net1gbe,jupyter,batch,fpga_compile
properties = xeon,skl,ram384gb,net1gbe,renderkit
properties = xeon,spr,ram1024gb,netgbe,dnp50
Many thanks in advance for you help!
xqyint
 it should be 4th Gen Intel Xeon, aka Sapphire Rapids.
SergeyV
 One may connect to a 4th gen node with the following command:
qsub -I -l nodes=1:spr:ppn=2 -d .
I have a question with respect to trying DSA tech acceleration. I can see eligible devices with lspci | grep 0b25 command, but there is no accel-config utility.  Can this be installed? I am unable to compile the code from https://github.com/intel/idxd-config in the user folder.
Thank you.
Sergey
