Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Account issues
ymq1010
我一直无法在For the Edge中使用容器化开发,查了几个帖子,问题都是一样的,非个人可以解决,麻烦帮忙,谢谢!
问:我已经注册了开发者云账户并完成激活,但是在For the Edge中开始使用容器化开发时,出现错误,无法访问,提示如下信息:“激活英特尔® DevCloud帐户,看起来您的帐户尚未注册。请注册您的帐户,然后重试.” 事实上,我已经注册并激活了我的云帐户。如果我单击下面的注册链接,它会提醒我我已注册英特尔® 开发人员云。跳转还会提示“您已经拥有与此电子邮件关联的英特尔开发者云帐户。” 那么 DevCloud for Edge 下的容器化开发仍然无法使用。
即使您注销帐户并重新登录,该错误仍然会发生。
AlekhyaV_Intel
Thank you for posting in Intel Communities. We only provide support in English. I have translated your question as follows:
Account issues
I haven't been able to use containerized development in for the edge, checked a few posts, the problem is the same, non-personal can be solved, trouble help, thanks!
Q: I have registered a Developer Cloud account and completed activation, but when I start using containerized development in For the Edge, I get an error and cannot access it with the following message: "Activate your Intel DevCloud account, it looks like your ® account is not registered." Please register your account and try again. In fact, I have registered and activated my cloud account. If I click on the registration link below, it reminds me that I am registered for Intel ® Developer Cloud. The jump also prompts "You already have an Intel Developer Cloud account associated with this email." ”Then containerized development under DevCloud for Edge is still unusable.
The error still occurs even if you log out of your account and log back in.
Does this reflect your query correctly?
Alekhya
AlekhyaV_Intel
Does our translation reflect your query correctly? Please give us an update regarding this issue.
Alekhya
AlekhyaV_Intel
We have not heard back from you, hence, we will close this thread now. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
