Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1715 Discussions
Agilex nodes offline and not accessible from devcloud_login
bxbxf
I am trying to run tests on Agilex FPGAs but they seem to be missing from devcloudLoginTools because when execute the devcloud_login command it only shows me :
You are selecting an interactive compute server sesssion. Please consider using batch mode submission using
devcloud_login -b to not tie up compute servers with idle sessions.
See the help menu using devcloud_login -h for more details.
What are you trying to use the Devcloud for?
1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL
2) Arria 10 - OneAPI, OpenVINO
3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL
4) Stratix 10 - OneAPI, OpenVINO
5) Compilation (Command Line) Only
6) Enter Specific Node Number
When I typed :
pbsnodes | grep -B 4 agilex
It shows me the following three nodes and they are all offline :
s006-n001
     state = down,offline
     power_state = Running
     np = 2
     properties = xeon,skl,gold6128,ram192gb,net1gbe,fpga_runtime,fpga,agilex
s006-n002
     state = offline
     np = 2
s006-n003
     state = offline
     np = 2
Is it just a coincidence that they are all offline or are they down ?
Thanks!
ThasneemV_Intel
We are checking on this internally. We will get back to you soon with an update.
Thasneem Vazim
ThasneemV_Intel
Thank you for your patience.
The Agilex nodes are currently in the preprocessing stage, which means their availability will be intermittent. We apologize for any inconvenience caused. We are actively working on optimizing their performance. Properly tested Agilex cards will be added shortly.
Thasneem Vazim
bxbxf
Is there any timeline when they are going to be available for public use ?
ThasneemV_Intel
We will inform you regarding the timeline once we receive clarification from the admin team.
Thasneem Vazim
ThasneemV_Intel
You can expect new FPGA cards (Agilex) to be available by the end of July.
Hope this is helpful. If this resolves your issue, kindly mark this as a solution as this might help others with a similar issue.
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
ThasneemV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
