You probably noticed the following warning when trying to connect to oneAPI DevCloud:
$ ssh devcloud
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ED25519 key sent by the remote host is
SHA256:/Dlip01tdMyRmhMDc870Z4Uk7AancwwoTnbb0EZajK0.
Please contact your system administrator.
Add correct host key in /home/<user_name>/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /home/<user_name>/.ssh/known_hosts:#
Host key for ssh.devcloud.intel.com has changed and you have requested strict checking.
Host key verification failed.
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
Cause:
We have just migrated oneAPI DevCloud to a new SSH tunnel server and upgraded the SSH server version to OpenSSH _8.2p1. For this reason the we are unable to reuse the old SSH fingerprint for the new server.
Remediation:
Step 1: remove the offending fingerprint(s).
Method 1: rename your existing ~/.ssh/known_hosts file to something else, such as ~/.ssh/known_hosts.yymmdd
$ mv ~/.ssh/known_hosts ~/.ssh/known_hosts.220623
Method 2: remove the offending host SSH fingerprint only:
$ ssh-keygen -R ssh.devcloud.intel.com
# Host ssh.devcloud.intel.com found: line 1
# Host ssh.devcloud.intel.com found: line 2
# Host ssh.devcloud.intel.com found: line 3
/home/<user_name>/.ssh/known_hosts updated.
Original contents retained as /home/<user_name>/.ssh/known_hosts.old
Step 2: reconnect to the DevCloud and accept the new key.
$ ssh devcloud
The authenticity of host 'ssh.devcloud.intel.com (12.229.61.118)' can't be established.
ED25519 key fingerprint is SHA256:/Dlip01tdMyRmhMDc870Z4Uk7AancwwoTnbb0EZajK0.
This key is not known by any other names
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added 'ssh.devcloud.intel.com' (ED25519) to the list of known hosts.
Please let us know if you encounter any issues.
Thank you.
The Intel DevCloud team.
