Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
Arria 10 - Uninitialized
aamila
we are trying to use Arria 10 on Intel DevCloud to compile some OpenCL code, however the device status is "Uninitialized". This has worked before, however in the last two days it is not working. Please advise us what to do.
I'm providing the output of "aocl diagnose" command:
u172aaa@s005-n002:~$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 2 icd entry at that location:
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
the following OpenCL libraries are referenced in the icd files:
libalteracl.so
libintelocl_emu.so
checking LD_LIBRARY_PATH for registered libraries:
libalteracl.so was registered on the system at /glob/development-tools/versions/fpgasupportstack/a10/1.2.1/intelFPGA_pro/hld/host/linux64/lib
libintelocl_emu.so was registered on the system at /glob/development-tools/versions/fpgasupportstack/a10/1.2.1/intelFPGA_pro/hld/host/linux64/lib
Using the following location for fcd installations:
/opt/Intel/OpenCL/Boards
Found 1 fcd entry at that location:
/opt/Intel/OpenCL/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
/opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so
/opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 2
1. Intel(R) FPGA SDK for OpenCL(TM)                             | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.4
2. Intel(R) FPGA Emulation Platform for OpenCL(TM)              | Intel(R) Corporation           | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
ICD diagnostics PASSED
BSP Diagnostics
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
Physical Dev Name   Status            Information
pac_ee00000         Uninitialized     OpenCL BSP not loaded. Must load BSP using command:
                                      'aocl program <device_name> <aocx_file>'
                                      before running OpenCL programs using this device
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
aamila
Trying to program the device also generates a problem.
u172aaa@s005-n002:~/A10_OPENCL_AFU/vector_add/bin$ aocl program acl0 vector_add_fpga.aocx
aocl program: Running program from /opt/a10/inteldevstack/a10_gx_pac_ias_1_2_1_pv/opencl/opencl_bsp/linux64/libexec
libopae-c reconf.c:427:fpgaReconfigureSlot() **ERROR** : Failed to reconfigure bitstream: Input/output error
libopae-c reconf.c:450:fpgaReconfigureSlot() **ERROR** : PR incompatible bitstream error detected
Error writing bitstream to FPGA: reconfiguration error
Error programming device
aocl program: Program failed.
AayushiR_Intel
We are working on this internally and get back to you soon.
Aayushi
AayushiR_Intel
We are sorry for the delay.
You can run the below command.
aocl initialize acl0
Since the BSP is properly installed this will initialize the FPGA and have it ready for programming.
Aayushi
AayushiR_Intel
We have not heard back from you. Could you please provide the updates.
Aayushi
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
