--------------------------------------------------------------------------- AttributeError Traceback (most recent call last) <ipython-input-17-71ae8829a053> in <module> 1 get_ipython().system('pip3 install torch==1.2.0+cu92 torchvision==0.4.0+cu92 -f https://download.pytorch.org/whl/torch_stable.html') ----> 2 torch.is_cuda AttributeError: module 'torch' has no attribute 'is_cuda'
please help with this error
- Tags:
- General Support
Thank you for posting your questions.
First of all use torch.cuda.is_available() to detemine the CUDA availability also we need more details to figure out the issue.Could you provide us the commands and steps you followed?
I am actually pruning my model using a particular torch library for pruning
then this is what happens
model structure
device = torch.device("cuda" if torch.cuda.is_available() else "cpu")
class C3D(nn.Module):
The C3D network.
def __init__(self, num_classes, pretrained=False):
super(C3D, self).__init__()
self.conv1 = nn.quantized.Conv3d(3, 64, kernel_size=(3, 3, 3), padding=(1, 1, 1))#.....54.14ms
self.pool1 = nn.MaxPool3d(kernel_size=(1, 2, 2), stride=(1, 2, 2))
self.conv2 = nn.quantized.Conv3d(64, 128, kernel_size=(3, 3, 3), padding=(1, 1, 1))#**...395.749ms**
self.pool2 = nn.MaxPool3d(kernel_size=(2, 2, 2), stride=(2, 2, 2))
self.conv3a = nn.quantized.Conv3d(128, 256, kernel_size=(3, 3, 3), padding=(1, 1, 1))#.....208.237ms
self.conv3b = nn.quantized.Conv3d(256, 256, kernel_size=(3, 3, 3), padding=(1, 1, 1))#***..348.491ms***
self.pool3 = nn.MaxPool3d(kernel_size=(2, 2, 2), stride=(2, 2, 2))
self.conv4a = nn.quantized.Conv3d(256, 512, kernel_size=(3, 3, 3), padding=(1, 1, 1))#.....64.714ms
self.conv4b = nn.quantized.Conv3d(512, 512, kernel_size=(3, 3, 3), padding=(1, 1, 1))#.....169.855ms
self.pool4 = nn.MaxPool3d(kernel_size=(2, 2, 2), stride=(2, 2, 2))
self.conv5a = nn.quantized.Conv3d(512, 512, kernel_size=(3, 3, 3), padding=(1, 1, 1))#....27.173ms
self.conv5b = nn.quantized.Conv3d(512, 512, kernel_size=(3, 3, 3), padding=(1, 1, 1))#....25.972ms
self.pool5 = nn.MaxPool3d(kernel_size=(2, 2, 2), stride=(2, 2, 2), padding=(0, 1, 1))
self.fc6 = nn.Linear(8192, 4096)#......21.852ms
self.fc7 = nn.Linear(4096, 4096)#.......10.288ms
self.fc8 = nn.Linear(4096, num_classes)#...0.023ms
self.dropout = nn.Dropout(p=0.5)
self.relu = nn.ReLU()
self.softmax = nn.Softmax(dim=1)
self.__init_weight()
def forward(self, x):
x = self.relu(self.conv1(x))
x = least_squares(self.pool1(x))
x = self.relu(self.conv2(x))
x = least_squares(self.pool2(x))
x = self.relu(self.conv3a(x))
x = self.relu(self.conv3b(x))
x = least_squares(self.pool3(x))
x = self.relu(self.conv4a(x))
x = self.relu(self.conv4b(x))
x = least_squares(self.pool4(x))
x = self.relu(self.conv5a(x))
x = self.relu(self.conv5b(x))
x = least_squares(self.pool5(x))
x = x.view(-1, 8192)
x = self.relu(self.fc6(x))
x = self.dropout(x)
x = self.relu(self.fc7(x))
x = self.dropout(x)
logits = self.fc8(x)
#probs = self.softmax(logits)
return logits
def __init_weight(self):
for m in self.modules():
if isinstance(m, nn.Conv3d):
init.xavier_normal_(m.weight.data)
init.constant_(m.bias.data, 0.01)
elif isinstance(m, nn.Linear):
then later on when I prune the model
import torch.nn.utils.prune as prune
model = C3D(num_classes=2).to(device=device)
prune.random_unstructured(module, name="weight", amount=0.3)
parameters_to_prune = (
(model.conv2, 'weight'),
(model.conv3a, 'weight'),
(model.conv3b, 'weight'),
(model.conv4a, 'weight'),
(model.conv4b, 'weight'),
(model.conv5a, 'weight'),
(model.conv5b, 'weight'),
(model.fc6, 'weight'),
(model.fc7, 'weight'),
(model.fc8, 'weight'),
prune.global_unstructured(
parameters_to_prune,
pruning_method=prune.L1Unstructured,
amount=0.2
This is the error I get
--------------------------------------------------------------------------- AttributeError Traceback (most recent call last) <ipython-input-21-e36bdf219c8c> in <module> 19 parameters_to_prune, 20 pruning_method=prune.L1Unstructured, ---> 21 amount=0.2 22 ) ~/.local/lib/python3.7/site-packages/torch/nn/utils/prune.py in global_unstructured(parameters, pruning_method, **kwargs) 1017 1018 # flatten parameter values to consider them all at once in global pruning -> 1019 t = torch.nn.utils.parameters_to_vector([getattr(*p) for p in parameters]) 1020 # similarly, flatten the masks (if they exist), or use a flattened vector 1021 # of 1s of the same dimensions as t ~/.local/lib/python3.7/site-packages/torch/nn/utils/convert_parameters.py in parameters_to_vector(parameters) 18 for param in parameters: 19 # Ensure the parameters are located in the same device ---> 20 param_device = _check_param_device(param, param_device) 21 22 vec.append(param.view(-1)) ~/.local/lib/python3.7/site-packages/torch/nn/utils/convert_parameters.py in _check_param_device(param, old_param_device) 71 # Meet the first parameter 72 if old_param_device is None: ---> 73 old_param_device = param.get_device() if param.is_cuda else -1 74 else: 75 warn = False AttributeError: 'function' object has no attribute 'is_cuda'
please help
prune.global_unstructured when I use prune.global_unstructure I get that error
please help
Hi Franck,
Thanks for the update.
To figure out the exact issue we need your code and steps to test from our end.Could you share the entire code and steps in a zip file?
ok
Sorry for late response
Sorry for the late response.
We tried running your code.The issue seems to be with the quantized.Conv3d, instead you can use normal convolution3d.
Since this issue is not related to Intel Devcloud can we close the case?
Could you give us an update?
We are closing the case assuming that your issue got resolved.Please raise a new thread in case of any further issues.
