Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
Automatic script to install Midnight Commander (MC) LOCALLY
STyur
Usually, one of the first command to invoke on just installed Lunux is `apt install mc`. Unfortunately, it is not work on devcloud virtual machine, but you can easy install it locally for user by script attached to this post.
After execute the script, you have to exit from console and enter to it to make some paths actual.
Script:
#!/bin/bash
install_local_lib(){
apt download $1
LIB_UNPACK_DEB=`ls | grep "$1"|grep '.deb'`
dpkg -x $LIB_UNPACK_DEB $1
cp -f $1/usr/lib/x86_64-linux-gnu/* $HOME/.local/lib/
rm -rf $LIB_UNPACK_DEB $1
if [[ -z `cat $HOME/.bash_profile|grep 'var_add_path()'` ]]; then
cat << 'EOF' >> $HOME/.bash_profile
function var_add_path(){
# Use var_add_path "VAR" "/path/to/smth" "s|e"
# s - at the beginning; e - at the end
# echo "Adding $2 to $1 at the <start|end> $3"
  tmp_var=$1
  if [ -d "$2" ]; then
    if [[ ":${!tmp_var}:" != *":$2:"* ]]; then
      # For non-empty, only add if not already there
      if [[ "$3" == "s" ]]; then
    [[ -z "${!tmp_var}" ]] && export $1=$2 || export $1=$2:${!tmp_var}
      else
    [[ -z "${!tmp_var}" ]] && export $1=$2 || export $1=${!tmp_var}:$2
      fi
    fi
  fi
var_add_path "PATH" "$HOME/.local/bin" "s"
var_add_path "PATH" "$HOME/bin" "s"
var_add_path "PATH" "/bin" "e"
var_add_path "LD_LIBRARY_PATH" "$HOME/.local/lib" "e"
EOF
fi
if [[ -z `cat $HOME/.bash_profile|grep 'export MC_DATADIR='` ]]; then
export MC_DATADIR=$HOME/.local/share/mc
EOF
fi
[[ ! -d $HOME/src ]] && mkdir $HOME/src
cd $HOME/src
install_local_lib "libssh2-1"
# install_local_lib "libslang2"
# install_local_lib "libgpm2"
# install_local_lib "libglib2.0-0"
# install_local_lib "libext2fs2"
# install_local_lib "libc6"
apt download mc
MC_DIST_DEB=`ls | grep 'mc'|grep '.deb'`
dpkg -x $MC_DIST_DEB mc
sed -i 's,\/usr\/lib\/mc\/ext.d,~\/.local\/lib\/mc\/ext.d,' mc/etc/mc/mc.ext
cp -rf mc/etc/mc $HOME/.config/
cp -f  mc/etc/mc/sfs.ini $HOME/.local/share/mc/
cp -rf mc/usr/bin $HOME/
cp -rf mc/usr/lib $HOME/.local/
cp -rf mc/usr/share $HOME/.local/
apt download mc-data
MCD_DIST_DEB=`ls | grep "mc-data"|grep '.deb'`
dpkg -x $MCD_DIST_DEB mc-data
cp -rf mc-data/usr/share $HOME/.local/
[[ ! -d $HOME/.config/mc/mcedit ]] && mkdir $HOME/.config/mc/mcedit
cp -rf mc-data/usr/share/mc/syntax/*  $HOME/.config/mc/mcedit/
cat << 'EOF' > $HOME/.selected_editor
# Generated by /usr/bin/select-editor
SELECTED_EDITOR="$HOME/bin/mcedit"
EOF
rm -rf $MC_DIST_DEB $MCD_DIST_DEB mc mc-data
Adweidh_Intel
Dear Tyurin,
Thanks for the information, we had informed concerned team about this.
Adweidh_Intel
Dear Tyurin,
Intel DevCloud® is a shared environment which comes with pre-installed validated Intel® oneAPI software and complimentary packages. As a policy we do not install custom (open source or 3rd party licensed) software to the environment and recommend that you explore available and equivalent oneAPI SW tools or components.  You may be able to install software locally in your user folder.
STyur
Adweidh_Intel (Intel) wrote:
Dear Tyurin,
Thanks for point.
This script is designed exactly for user local installation of MC.
I changed the title to clarify this.
Adweidh_Intel
Dear Tyurin,
Thanks for updating the title, this will be really helpful for the users.
Shall we close this thread ?
STyur
Yes, you can close the thread.
Tchouanga__Franck
please help I am unable to post an issue again I am getting the below errors
The form has become outdated. Copy any unsaved work in the form below and then reload this page.
please how can I solve that
Adweidh_Intel
Dear Tyurin,
We are closing this thread, in case of any issues kindly raise a new thread.
Dear Tchouanga,
We have informed this issue with concerned team, there will be a quick fix on same.
