Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1637 Discussions
Basekit vector-add example fails on epilogue
Victor_E_1
On https://devcloud.intel.com/oneapi/get-started/base-toolkit/
the build & run script both give a PBS error:
/var/spool/torque/mom_priv/epilogue.parallel: line 12: /var/spool/torque/mom_priv/epilogue.d//95-nvdir.epilogue: Permission denied
RahulV_intel
Hi Victor,
We are unable to recreate the issue. The vector add sample works fine for us in DevCloud. Did you follow the exact steps mentioned in the https://devcloud.intel.com/oneapi/get-started/base-toolkit/ ?
Victor_E_1
You are running interactively. Please read my question: I am making PBS scripts as requested. Those don't work.
Build and run the sample in batch mode
The following describes the process of submitting build and run jobs to PBS.
A job is a script that is submitted to PBS through the qsub utility. By default, the qsub utility does not inherit the current environment variables or your current working directory. For this reason, it is necessary to submit jobs as scripts that handle the setup of the environment variables. In order to address the working directory issue, you can either use absolute paths or pass the -d <dir> option to qsub to set the working directory.
Create the job scripts
Create a build.sh script with the following contents.
#!/bin/bash source /opt/intel/inteloneapi/setvars.sh make clean make all
Bash
Copy
Create a run.sh script with the following contents for executing the sample.
#!/bin/bash source /opt/intel/inteloneapi/setvars.sh make run
Bash
Copy
Build and run
Jobs submitted in batch mode are placed in a queue waiting for the necessary resources (compute nodes) to become available. The jobs will be executed on a first come basis on the first available node(s) having the requested property or label.
Build the sample on a gpu node.
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
Bash
Copy
Note: -l nodes=1:gpu:ppn=2 (lower case L) is used to assign one full GPU node to the job.
Note: The -d . is used to configure the current folder as the working directory for the task.
In batch mode, the commands return immediately; however, the job itself may take longer to complete. In order to inspect the job progress, use the qstat utility.
watch -n 1 qstat -n -1
Bash
Copy
Note: The watch -n 1 command is used to run qstat -n -1 and display its results every second.
Run the sample on a gpu node after the build job completes successfully.
qsub -l nodes=1:gpu:ppn=2 -d . run.sh
Bash
Copy
The best way to determine whether a job completed or not is by using the qstat utility. When a job terminates, a couple of files are written to the disk:
RahulV_intel
We are able to build/run the vector-add sample using non-interactive mode(PBS/Batch mode). PFA screenshots for reference(zip file). We suggest you to try running the sample using the interactive mode and let us know if it works. Also make sure that you are following exact steps from this link: https://devcloud.intel.com/oneapi/get-started/base-toolkit/#cpu-gpu-vector-add-sample-walkthrough.
GouthamK_Intel
Hi Victor,
Can you please provide us the update on whether you were able to run the sample code with suggested steps by Rahul.
Please let us know whether your issue is resolved or not.
Goutham
Victor_E_1
Batch jobs still give an error:
u37709@login-2:~/sycltrain/9_sycl_of_hell$ pwd
/home/u37709/sycltrain/9_sycl_of_hell
u37709@login-2:~/sycltrain/9_sycl_of_hell$ cat build.sh
#!/bin/bash
make
u37709@login-2:~/sycltrain/9_sycl_of_hell$ cat *e*94
(how does this markup system work? is there a way to mark a block of text as literal/monospace/no-html?)
RahulV_intel
Hi Victor,
The epilogue error has been fixed now (which was persisting previously on few of the nodes). Could you try the sample now and check if it works? Let us know in case you face any issues.
-Rahul
RahulV_intel
We are closing this thread, assuming that your issue is resolved. Feel free to post a new question if your issue still persists.
--Rahul
